Hi friends,
I have a bioreactor filled with (L'urie de porc) this to be trated and the final objective to produce (Angrais).
the bioreactor is underground (90% undeground).
the problem is that the temperature is very high (more than 40C AT A LOW FEED (50% OF THE TOTAL FEED) and I want a temperature of 32C to have an exothermic reaction.
I have a feed 100T/D, Air enter compressor (the outlet temperature 100C and 3700 NM3/HR
BIOREACTOR VOLUME IS V : KNOWN
I used a mass balance and energy balance but steel a problem of high temperature
don't forgot conditions in winter and in summer ( location CANADA).
i AM WAITING FOR YOUR HELP
Cstr Reactor
Started by you, Nov 28 2006 07:44 PM
![]() Multi-Tubular Packed Bed ReactorStarted by Guest_shambola_* , 12 Feb 2025 |
![]() Help On Simulation Of Reactor In Aspen PlusStarted by Guest_m.ghaziasgar_* , 06 Jan 2025 |
Secondary Heating Loop For ReactorStarted by Guest_TheChemEng_* , 28 Nov 2024 |
![]() Need Help For Utility Flow Rate Calculation For A Chemical ReactorStarted by Guest_Asisr_* , 12 Sep 2024 |
