Nitrogen Package
#1 Ali4269278331
Ali4269278331
  • 31 posts
Posted 06 April 2024 - 08:00 PM
hi, our site equip with nitrogen package as portable. this package consist of storage vessel, evaporator and N2 liquid to gas. the location of N2 package is near the oil storage tanks approx. 15mt far from together. i would like to know in the process plant layout this arrangement is correct or not? which is standard refer for this layout?
thanks
Ali
#2 fallah
  • 5,026 posts
Posted 06 April 2024 - 08:49 PM
As the package is portable, let's know about your main problem?
#3 breizh
  • 6,940 posts
Posted 06 April 2024 - 09:11 PM
To second Naser, what is your fear?
 N2 unloading?
 Oil flammability?
Did you check with your HSE manager and/or the fire brigade in your area?
Note: You may have specific regulations in your country, check with the safety bureau.
#4 shvet1
shvet1
  • 476 posts
Posted 09 April 2024 - 12:10 AM   Best Answer
Equipment siting/layout is not a simple question as so many factors are involved. Your question concerns zoning (fire, ex) - note that any option is possible if it had been justified properly. Resulted risk rate is the only issue.
Start with consulting your local insurance company
https://files.engine...Association.pdf
Edited by shvet1, 09 April 2024 - 12:16 AM.
#5 Ali4269278331
Ali4269278331
  • 31 posts
Posted 09 April 2024 - 01:33 PM
thanks dear Fallah, please consider HAZOP and HAZID in your answer. our problem are based on HSE.
#6 Ali4269278331
Ali4269278331
  • 31 posts
Posted 09 April 2024 - 01:35 PM
thanks , please consider HAZOP and HAZID in your answer. our problem are based on HSE.
#7 Pilesar
  • 1,637 posts
Posted 10 April 2024 - 06:09 AM
There is no single right way to lay out equipment in a plant.The HAZOP/HAZID will have questions like 'what are the consequences of damage to the nitrogen package? Is the nitrogen package at risk of external fire or other damage?' If there is a hazard identified, then it must be safeguarded or accepted.
