Caloric Temperature Calculation
#1 bckesim
bckesim
  • 5 posts
Posted 10 April 2024 - 02:57 PM
In Kern's Process Heat Transfer and TEMA Standards, calculation procedures of caloric temperature for heat exchangers having cocurrent and countercurrent flow arrangments are available. However, I need to calculate it for a 1 shell-side pass, 2 tube-side passes shell and tube heat exchanger. Can somebody give me the calculation procedure for other types of flow arrangements?
Thanks!
  • 7,037 posts
Posted 11 April 2024 - 05:19 AM
You may find what you are looking for using this calculator.
CheCalc ‐ Logarithmic Mean Temperature Difference LMTD Correction Factor Charts
#3 bckesim
bckesim
  • 5 posts
Posted 18 April 2024 - 05:34 AM
Do you have any idea how HTRI calculates LMTD correction factor? Actually I want to calculate MTD and DELTA in the following formula used in HTRI: EMTD = (MTD) * (DELTA) * (F/G/H)
#4 breizh
  • 7,037 posts
Posted 18 April 2024 - 07:45 AM
I cannot support, not having simulator but if you google "EMTD = (MTD) * (DELTA) * (F/G/H)" you will be surprised.
