Distributor Pipe
Posted 29 November 2006 - 04:57 AM
I have to design the spreaders ( sort of spargers) for curde oil distribution in storage tank (which is being used for the purpose of Oil/Water separation). This spreaders are basically used for the purpose of uniform distribution of crude across the tank area (Tank diameter - 120'). Also, the collector spreaders are used for draw-off of seperated Oil from top level and water from bottom level. Collecotrs are also similar to spreader but flow of fluid is in opposite direction.
But in existing tanks, we are finding a lot of back pressure!!! We are unable to quantify the back pressure and also what would be the optimum hole size and quantity to be provided for given flow and given fluid properties.
I request all my friends in this forum to help to find the proper technical information on which I can develop the design module for sizing pipe size, hole size and no. of holes to avoid back pressure.
Looking forward to valuable suggestions from you guys.
Thanks,
Shivakumar Angadi
Joint Operations - Kuwait Gulf Oil Company & Saudi Arabian Texaco
Wafra, Kuwait
sazp@chevrontexaco.net
Posted 29 November 2006 - 08:42 AM
About your question, you can review at Perry's Chemical Engineers' Handbook by Perry and Greene.
Chapter 6: FLUID AND PARTICLE DYNAMICS page 6-32 till 6-34 subjet: FLUID DISTRIBUTION this subject has an example.
I think this article solve your problem. But for purposes of collectors, I think they are ok. If you prevent plugging of holes.
Posted 29 November 2006 - 09:28 PM
1. "Simplified Sparger Design", Kent S. Knaebel, Chemical Engineering Magazine, March 9, 1981 (Plant Notebook)
2. "Hole-area distribution for liquid spargers-A correction", W. H. Mink, Chemical Engineering Magazine, April 6, 1981
The last article gives a program for the TI (Texas Instrument) Calculator #59. A companion article in Fluid Flow magazine presents a version in BASIC. I don't have the exact date for this article but is looks like sometime around 1984 or 85.
Posted 05 December 2006 - 06:00 AM
If u get any material in this reagard, please assist me in providing the same.
Thanks again.
Shivku
Posted 05 December 2006 - 08:13 PM
Attached I send you an article about Design of Gas distributors from Chemical Engineering.
Posted 11 December 2006 - 04:49 AM
Posted 13 February 2007 - 01:32 PM
Profe,
Can you please send me that article on gas distributors?
Email: rali@sidrich.com
Posted 13 February 2007 - 02:31 PM
I sent you the article about Design of Gas distributors from Chemical Engineering.
at your e-mail direction.
Posted 28 June 2007 - 09:50 PM
Could you send me the article as well?
my email address : teaaon@techint.com
Posted 29 June 2007 - 05:30 PM
I sent you the pdf copy of article requested me at your e-mail address.
Posted 30 June 2007 - 02:03 AM
Hi All,
Is this a copyrighted document ? Surprisingly nobody (those who are concern) voice similar concern...
http://www.cheresour...?showtopic=3437
http://www.cheresour...?showtopic=3432
JoeWong
#12
Posted 30 June 2007 - 04:07 AM
Although I read many topics/threads in this forum I do no read all of them...
#13
Posted 30 June 2007 - 06:58 PM
#14
Posted 10 July 2007 - 07:29 AM
kindly send me the article at abiodun.a@atlasengineering-ng.com
#15
Posted 04 August 2009 - 03:56 AM
Kindly send me that article(s) on distributors to vijay078@yahoo.com
Thanks in advance.
#16
Posted 13 August 2009 - 08:08 AM
at your e-mail direction at your e-mail adress: vijay078@yahoo.com
Please let me know if you received this e-mail and comments about the article.
Posted 03 September 2009 - 03:55 AM
Hi Invinci
Profe,
I too need this article. Could you be kind enough to send it at:
ankur_2061@hotmail.com
#18
Posted 03 September 2009 - 11:38 PM
A couple of years back I had done some calcutions for column pipe distributors to verify vedor datasheets.Am attaching the file.
People can Vadidate/modify the calculation for theie own use.There are no references or gaurantees for the calculation.You might use it for some quick checks...Suggestions are welcome.
Posted 09 September 2009 - 02:44 PM
#20
Posted 06 May 2010 - 01:53 AM
Could be send me the artcile on the gas distributor as well on my email address as below
kishore.praveen@gmail.com
Many Thanks
Rgds
Praveen
#21
Posted 13 May 2010 - 08:55 AM
I sent at your e-mail address: kishore.praveen@gmail.com the pdf file about Design of gas distributor.
Please confirm me if you receive that information.
Good luck.
Edited by Profe, 13 May 2010 - 08:59 AM.
#22
Posted 09 September 2010 - 07:43 AM
Could I please also get a copy of this article. Much appreciated. romizam@live.com
Hi Praveen
Good luck.
[/quote]
#23
Posted 04 October 2010 - 10:02 PM
Hi Profe,
May i get a copy as well?
my email: tew-525@hotmail.com
Thanks a lot.
#24
Posted 19 November 2010 - 10:18 AM
Could you send me a copy as well?
my email is: anpasc@yahoo.it
Thanks a lot.
#25
Posted 17 February 2012 - 12:33 AM
aj@canwell.com
Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
