Distributor Pipe
Started by shivku, Nov 29 2006 04:57 AM
34 replies to this topic
Posted 08 May 2012 - 11:21 AM
Profe,
I need these articles. Kindly send it at:
jetul@rediffmail.com
Jetul.
Jetul.
#27
Posted 09 May 2012 - 07:57 AM
Hi all who interested in this subject.
Attached you will find two articles for distributors
Good luck.
Good luck.
Posted 10 July 2012 - 04:53 PM
Dear Profe,
Could you please send me a copy of steam sparger article too?
#29
Posted 04 December 2012 - 09:13 AM
#30
Posted 04 December 2012 - 10:46 AM
Hi SubbuVenkat
About your request, please review two post before (the number 27) and you can download the pdf articles.
Good luck.
Good luck.
#31
Posted 04 December 2012 - 09:19 PM
Shiva
1. The critical design parameter is to limit the velocity of crude for each slot of not more than 1 m/s. (3 ft/s).
2. From the flowrate, determine the total number of slots required to meet the velocity limit. Typical length of slot is 12" and the slot width may range from 4" to 8" depending on the total flowrate.
3. Do trial and error to determine the total length of distributor that meet the tank diameter and the velocity criteria.
4. Unable to provide more details (drawings) due to proprietary nature of the information but use you creativity in the design.
5. I suggest that you prepare the proposed sketch (drawing) based on your creativity for further comments and suggestion for further improvement since I have a typical figure of the distributor.
Edited by S.AHMAD, 04 December 2012 - 09:25 PM.
#32
Posted 05 December 2012 - 05:05 AM
Hi Profe,
Could I please also get a copy of this article. Much appreciated.
rodscott2@yahoo.com.br
Thanks in advance!
Rodscott
Thanks in advance!
Rodscott
#33
Posted 06 December 2012 - 09:23 PM
#34
Posted 10 February 2013 - 10:08 PM
#35
Posted 23 February 2013 - 05:36 AM
kindly send the article of gas distributor at punamchem06@gmail.com
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
Velocity In A Vertical Pipe Or Open PipeStarted by Guest_jango_* , 02 Dec 2025 |
Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
