Dear all,
Can any one tell me what should be the mimnimum pressure drop in control valve in feed water line of boilers ?
Minimum Pressure Drop In Cv
Started by P R Mukkundi, Nov 30 2006 09:36 AM
Posted 30 November 2006 - 09:36 AM
Posted 30 November 2006 - 11:45 PM
QUOTE (P R Mukkundi @ Nov 30 2006, 11:36 PM) <{POST_SNAPBACK}>
Dear all,
In any kind of liquid line, pressure drop of control valve should be
HIGHER of the following two values
[1] 1.0 bar
[2] approximately 30% of the frictional pressure drop of the total loop. This means you need not take into account the pressure loss due to static height & equipment(s) while calculating 30%.
The above values are good engineering practice(s). It may differ based on situatoin. The purpose of specifying these values is to enusre 'smooth' operation of control valve.
thank you,
Design Compressor For 35% H2S & 1.05Ksca Suction PressureStarted by Guest_GanjiS_* , 29 Apr 2024 |
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
Vapor PressureStarted by Guest_Hamza1111_* , 23 Mar 2024 |
