Air Separation Hysys Model
Posted 04 June 2024 - 12:40 PM
Thanks.
Posted 15 June 2024 - 10:44 PM
I don't have one on me.
AspenTech esupport Article ID: 000057332, does present an integrated column model for Hysys that produces O2, N2 and Ar. Just grab it off the web using your esupport registration details.
However, it presents a bit too "black box" for me. I like to get a feel for the working parts of a process simulation.
This thesis:
appears to detail an operating Linde design:
https://www.linde.co...f-india-limited
So, if you have to build a model from the ground up, then you've got a useful starting point that reflects an industrial example.
Details of key simulation parameters (such as number of column stages) are clearly stated along with details of the process heat & material balance tables. Many write ups that I can spot quickly, exclude this sort of detail which would make it harder to use as a go-by. The author has even shared column profile data in terms of composition, flow, temperature and pressure. Columns are often difficult to converge without good initialisation data, so this go-by provides a useful assist in that regard as well.
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
