Mdea Questions
#1 Board operator
Board operator
  • 3 posts
Posted 09 June 2024 - 06:36 PM
I have a question about MDEA regenerator. Is there a way of knowing how much reflux you should be producing in regenerator? and what the reflux flow rate should be? Also what's the purpose of a higher MDEA weight percent?
  • 1,691 posts
Posted 09 June 2024 - 08:38 PM
Distillation columns need enough reflux to meet separation specifications. So the reflux flow rate should be 'enough'. Water requires energy to boil. Where boiling water can be avoided, energy can be saved.
#3 Nikolay_
Nikolay_
  • 169 posts
Posted 09 June 2024 - 10:40 PM
Hi, you can find Btu/ft3*h lean amine in literature and conert it to Lb or kg/h steam. It is approximately equal vapor flow from top of column/reflux.
#4 shvet1
shvet1
  • 476 posts
Posted 10 June 2024 - 12:07 AM
Higher amine fraction => more H2S transfered => higher performance of treatment system
Higher amine fraction => higher temperature in reboiler => higher amine degradation rate
update
https://read.nxtbook...oda_ineos_.html
Edited by shvet1, 17 June 2024 - 08:21 AM.
