2
Mdea Solvet
#1 guoyinyanliner
guoyinyanliner
  • 83 posts
Posted 13 August 2026 - 06:20 AM
using activated MDEA + PZ solution for natural gas decarbonization, what is the typical packing height for common structured and random packings, such as Pall rings or 250Y structured packing? Also, where can I find or look up empirical HETP (Height Equivalent to a Theoretical Plate) data。
  • 7,058 posts
Posted 13 August 2026 - 08:04 AM
Consider these documents to support your work
#3 guoyinyanliner
guoyinyanliner
  • 83 posts
Posted 14 August 2026 - 12:05 AM
​"Could you please tell me directly
#4 breizh
  • 7,058 posts
Posted 14 August 2026 - 12:44 AM
Sorry, I'm just here to support, not more.
Norton's empirical correlation, rough estimate for random packings
base on liquid phase
Ln (HEPT)= n-0.187*ln (superficial tension) +0.213 *ln(viscosity)
HEPT in Feet
Superficial tension in dyne/cm
Viscosity in CPO
n=  depending on the choice of packing.
Ask Vendors for data on n
A few examples (from Google AI mode)
Intalox Metal packing (IMTP size #40/#50) n=1.13 to 1.15 high-performance metal packing
Pall Rings (2 inches/50 mm Metal /Plastic) n1.3 to 1.4
Rashig rings (1 inch, ceramic/metal n=1.55 to 1.7
Intalox saddles (1 inch/38 mm ceramic) n= 1.25 to 1.35
EDIT: Chinese supplier
Pingxiang Daier Separation Tech | High-end Structured Packing & Tower Internals - Tower Packing Basics | Random vs Structured, HETP, Geometry, Type Selection | Daier Engineering Reference
Good luck.
Engineering is about hard work ...
