I want to calculate how much heat is absorbed by an insulated spherical tank (containing propylene) from environment?
thanks a lot
Propylene is contained in saturation condition.
Posted 11 November 2024 - 03:01 AM
thanks a lot
Posted 11 November 2024 - 05:42 AM
is the temperature controlled?
Posted 06 January 2025 - 01:00 AM
You essentially need to do heat transfer calculation for natural convection and radiation due to solar insolation.
For natural convection, get some empirical correlation to obtain the effective HTC, considering some windspeed value.
For radiation, a reasonable estimate to use is 1000 W/m2 solar input.
But if you need to do this for some long time interval, you need to do a stepwise calculation as ambient temperature and solar insolation changes over time.
Electric Heat Tracing—Pipe-Wall Temperature Vs. Actual Fluid TemperatuStarted by Guest_zamakaze_* , 20 Sep 2026 |
Screening Heat & Material Balances Cases For Fire Relief Psv SizinStarted by Guest_powerox6_* , 21 Aug 2026 |
Storage Tank Relief LoadStarted by Guest_hum464_* , 10 Sep 2025 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
