Activated Carbon Selection
#1 Talhafarooq
Talhafarooq
Posted 25 November 2024 - 12:20 AM
Greetings All,
We want to know about the working tendency of our activated carbon filter on amine sweetening unit in lean amine circuit.
As part of a recent process adjustment, we  increase the flow rate from 25 m³/hr to 30 m³/hr to meet current operational requirements. In this case, we would like to inquire about several key specifications or charts related to the granular size of the activated carbon, including:
  • Recommended GPM/ft² values
  • Bed volume, length and diameter
  • Pressure drop considerations when passing lean amine
Another option we considering the replacement of a carbon filter with cartridge filters, it is essential to carefully evaluate the selection criteria and determine the appropriate number of cartridges, along with key operational parameters
  • filter volume, length and diameter
I am looking forward to your response.
  • 7,055 posts
Posted 25 November 2024 - 12:42 AM
Attached documents to support your work.
Note: probably good to ring your supplier for advises.
Edit: make sure you can dispose easily this material, very difficult in some countries.
