Please can someone advise what the viscosity of liquid nitrogen at -196degC is?
Thanks.
Viscosity Of Cryogenic Liquids
Started by rishel, Dec 07 2006 08:31 AM
Posted 07 December 2006 - 08:31 AM
Posted 07 December 2006 - 09:39 AM
rishel:
Find your answer(s) in the attached Excel Workbook.
You failed to state what pressure the Liquid Nitrogen (LIN) is at, so I assumed you mean SATURATED LIN and I got the range for 1 - 10 barA.
Note the data source. It took me less than a minute to generate this information from the time I read your post. This is what you should be resorting to when seeking out Thermodynamic Properties values. This information at NIST is totally free - and as accurate as you're going to get.
Posted 08 December 2006 - 06:19 AM
Hi there Art,
Thank you very much for the valuable info.
The pressure is 4.5barg, so the excel sheet definitely would help.
I was not ware of the site that you have mentioned, but will definitely view it.
Negative Sign In Newton's Law Of Viscosity?Started by Guest_Cheeky_* , 24 Oct 2024 |
Cryogenic Distillation To Produce Nitrogen GasStarted by Guest_Eng4324_* , 04 Mar 2024 |
![]() Design Considerations For Cryogenic Submersible PumpStarted by Guest_heydari_* , 04 Feb 2024 |
![]() Converging Cryogenic Air Separation In HysysStarted by Guest_rgc1994_* , 22 Mar 2017 |
Cryogenic Separation Of Steam Reforming SyngasStarted by Guest_Fjm989898_* , 15 May 2023 |
