Liquid Liquid Separator Sizing
separator design engineering process design process engineering
#1 Kentucky08
Kentucky08
  • 16 posts
Posted 03 April 2025 - 03:34 AM
Hi everyone,
I am currently designing a liquid-liquid separator for a mixture of FFA-glycerine with methanol. The process is as follows: the crude glycerine is sent to a process called acidification, where impurities, especially MONG, are removed by adding acid. After acidification, the mixture is sent to a decanter, where it separates into a layer of FFA-glycerine.
At this stage, I am designing the separator but am feeling a bit lost, particularly when it comes to assuming the properties to be used. I also have doubts about some of the values I’ve already calculated. As someone new to the industry and a recent graduate, I am reaching out for your help and expertise.
Attached is the work I have already started.
https://drive.google...iew?usp=sharing
Edited by Kentucky08, 03 April 2025 - 03:36 AM.
  • 7,030 posts
Posted 03 April 2025 - 04:16 AM
Consider this resource from Bobby. He was a member of this community.
 http://www.bobby-str...I_Decanter.aspx
Do you have access to real solutions? if yes perform test to get data about the decantation time. Several parameters to consider, temperature (viscosity), ratio aqueous phase / organic phase (could be modified by recirculation of one phase), coalescers to reduce the size of the decanter. Based on 8 years' experience designing and operating Mixer settlers for rare earths purification.
Check your document ( flow rate should be expressed in Kg/h )
Another resource could be Perry's chemical engineering handbook.
#3 haseeb2212
haseeb2212
  • 3 posts
Posted 02 May 2025 - 06:31 AM
Thank you very much Breizh. Provided literature and the link is really helpful.
I have 1 question, what is the sizing criteria for liquid inlet nozzle or any standard or specification where I can find that. In my case, its Glycol/water expansion vessel for cooling water circuit.
Thanks again!
#4 breizh
  • 7,030 posts
Posted 02 May 2025 - 07:00 AM
Consider this link:
BN-EG-UE109 Guide for Vessel Sizing
#5 Anastasia1905
Anastasia1905
  • 4 posts
Posted 08 July 2025 - 05:34 AM
Hi everyone!
Tell me, please, are there any standards other than API12J for selecting the liquid retention time in 3phase-separators?
How can we confirm that the liquid retention time is sufficient when the separator load increases?
Thanks in advance!
#6 breizh
  • 7,030 posts
Posted 08 July 2025 - 05:52 AM
Consider this document where you may find pointers.
Check your messenger box.
