Hi all,
I am sizing a compressor with suction of 150 psig and discharge of 2300 psig. The number of stages of compression is 3 stages.
Please, how can i determine the discharge pressure of the 1st and 2nd stage compressors.
Information is highly appreciated.
Thanks.
Compressor Sizing
Started by asade abiodun, Dec 13 2006 05:55 AM
Posted 13 December 2006 - 05:55 AM
Posted 13 December 2006 - 08:21 AM
Asade:
For a multi-stage reciprocating compressor it may be shown that the total power is a minimum when the ratio of compression in each stage is the same and the total horsepower is equally divided between stages..
R = P2 / P1
Where,
R = ratio compression over the compressor
P2 = Final absolute discharge pressure of the compressor, psia
P1 = Initial absolute suction pressure of the compressor, psia
For the ratio of compression to be the same between the various stages, the following is derived:
R = (P2 / P1)1/n
Where,
n = number of stages required.
Applying the above relationship, I obtain a compression ratio of 2.41325 between stages. Therefore,
Stage 1 discharge pressure = 397.4 psia
Stage 2 discharge pressure = 959.2 psia
I hope this helps.
R = P2 / P1
Where,
R = (P2 / P1)1/n
Where,
I hope this helps.
Posted 13 December 2006 - 08:30 AM
Hi Asade Abiodun
About your question, I think that you must review Thermodynamics. but for increase your Knowledge, attached I send a subject about Compressors. Reveiew it Thoroughly an at page 17 an 18 you will get about Multistage compressors and Inter stage pressure.
Posted 13 December 2006 - 09:49 AM
Art,
Thanks for the information.
Can the equation be used for multistage centrifugal compressors?
Posted 13 December 2006 - 01:04 PM
Hello Asade,
Dresser-Rand has interesting compressor sizing software. It is free for download:
http://www.dresser-r...fc/download.asp
Best regards
Best regards
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
