Distillation Column Top & Bottom Temperatures
#1 halkeshhulk
halkeshhulk
  • 25 posts
Posted 09 June 2025 - 01:45 AM
Q1. I would like to understand, how to finalize the top and bottom temperatures of the distillation column?
From my understanding the top temperature should be the above the dew point of the overhead vapor composition.
Bottom reboiler outlet temperature is based on the bottom products composition bubble point temperature and boil-up ratio, From bubble point of bottom product to %vaporization needed decides the temperature point in between its bubble and dew point of the mixture.
Kindly guide. Any references in evaluation of top and bottom temperatures in the columns helps. Thanks.
  • 6,939 posts
Posted 09 June 2025 - 06:30 AM
Distillation Tower Top And Bottom Temperature And Pressure - Student - Cheresources.com Community
#3 halkeshhulk
halkeshhulk
  • 25 posts
Posted 09 June 2025 - 10:12 AM
Thanks Breizh sir.
As per discussion on the above link, the Pressure of the column is choosen such that the dewpoint of the overhead stream stays at Temperature approach + CW Supply Temperature.
As the top temperature of the column doesn't get operated at the dewpoint point, is there any rule for column top Temperature to maintain some X degree above the dewpoint of the Overhead stream?
Kindly guide me.
#4 breizh
  • 6,939 posts
Posted 10 June 2025 - 12:49 AM
no, the objective of the condenser(total) is to condense the gas This means the cooling water should remove the latent heat of the gas and may be subcooled slightly the stream. you need to make sure the cooling water can perform the job in summer.
#5 halkeshhulk
halkeshhulk
  • 25 posts
Posted 10 June 2025 - 10:50 AM
Breizh sir,
We often see Air fin fan coolers followed by Cooling water Heat Exchanger right?
#6 breizh
  • 6,939 posts
Posted 10 June 2025 - 07:25 PM
It depends on industries.
my 2 cents
