Dew Point Calculation
#1 Aditya000333
Aditya000333
Posted 17 September 2025 - 04:37 AM
Dear all ,
I want to learn how to calculate dew point calculation for my main fractionator in delayed Coker unit with continuous varying feed to unit and fluctuating steam injection into system
#2 latexman
  • 1,895 posts
Posted 17 September 2025 - 05:18 AM
AI generated this answer.  A simulator is what I would recommend using.
A multicomponent dew point calculation involves iteratively assuming a temperature and calculating K-values for each component, then determining the liquid-phase mole fractions using the equation Xi = Yi / Ki. The dew point is reached when the sum of all liquid-phase mole fractions (ΣXi) equals one. For non-ideal mixtures, this involves solving complex equilibrium equations, often using Newton's method or other root-finding algorithms to find the correct temperature.
The Dew Point Calculation Process (Iterative Method)
  1. Assume a Temperature: Start by assuming a trial temperature for the mixture.
  2. Determine K-values: At the assumed temperature and given pressure, calculate the equilibrium K-value (Ki) for each component, where Ki = Yi / Xi (vapor mole fraction divided by liquid mole fraction). For non-ideal systems, these values are found using fugacity coefficients.
  3. Calculate Liquid Phase Compositions: Using the K-values, determine the mole fraction of each component in the liquid phase (Xi).
  4. Check the Sum of Liquid Compositions: Sum the calculated liquid mole fractions (ΣXi).
  5. Adjust Temperature:
    • If ΣXi = 1 (within a defined tolerance), the assumed temperature is the dew point.
    • If ΣXi > 1, the assumed temperature is too high, so you must lower it.
    • If ΣXi < 1, the assumed temperature is too low, so you must raise it.
  6. Repeat: Repeat steps 2-5 until the condition ΣXi = 1 is met.
Key Equations and Concepts
  • K-value:
    The ratio of vapor phase mole fraction to liquid phase mole fraction: Ki = Yi / Xi.
  • Liquid phase mole fraction (Xi):
    For a given component, Xi = Yi / Ki.
  • Summation condition:
    The dew point is the temperature where the sum of all liquid-phase mole fractions equals one: ΣXi = 1.
  • Non-Ideal Systems:
    For non-ideal mixtures, the calculation becomes more complex and often requires methods such as:
    • Poynting equationsfor liquid-phase pressure effects.
    • Fugacity coefficientsto account for deviations from ideal behavior.
    • Newton's methodfor solving the set of non-linear equations, which is a common root-finding technique for complex equilibrium problems.
#3 breizh
  • 6,947 posts
Posted 17 September 2025 - 07:27 AM
Another resource for your application is Google.
Attached an excel sheet for this type of calculation.
