I recently was tasked to help operate and oversee the drying of sludge using low temperature dryer which powered by hot water heated from excess steam.
To prepare myself i search about things that could go wrong in a steam/water process. I read that steam could create a vacuum when condensing and force water to fill that vacuum abruptly causing something similar to an explosion. So far from what i understand, the only way to prevent this phenomena is to prevent the condensation entirely along the pipeline. But now i wonder, how is this prevented in a heat exchanger system? or in an condenser system? where condensing is kinda inevitable
Posted 31 October 2025 - 04:12 AM
Posted 31 October 2025 - 05:55 AM
Like in a “Pick heater”? Pick heaters are engineered with a specific design to prevent pressure buildup and a helical internal chamber to ensure immediate and efficient mixing of steam with water, which eliminates the conditions that cause water hammer.
Water hammer is prevented in a steam heat exchanger by physically draining condensate from the system and controlling the startup and shutdown process. Key methods include using properly sized and located steam traps to remove condensate, ensuring the piping is sloped for drainage, and slowly opening valves during startup to warm the pipes gradually and avoid a dangerous mix of high-pressure steam and sub-cooled condensate.
Posted 31 October 2025 - 07:41 PM
Consider these resources.
Water Hammer in Condensate Transport Piping | TLV
Posted 04 November 2025 - 03:42 AM
What if instead of water its a closed loop refrigeration cycle. Is controlled draining stilll the solution?
Posted 04 November 2025 - 04:22 AM
Posted 04 November 2025 - 06:30 AM
Whatever two phase heat transfer fluid used, water, propane, ammonia, or refrigerants (like R-134a), hydraulic hammer is prevented in a heat exchanger by physically draining condensate from the system and controlling the startup and shutdown process.
Posted 10 November 2025 - 01:21 AM
But isn't draining not allowed in refrigeration cycle? since it is a closed loop.
Posted 10 November 2025 - 05:06 AM
Correction. Whatever two phase heat transfer fluid used, water, propane, ammonia, or refrigerants (like R-134a), hydraulic hammer is prevented in a heat exchanger by physically draining condensate away from the heat exchanger and controlling the startup and shutdown process. The condensate can be directed to an accumulator/reservoir within the closed system.
Posted 10 November 2025 - 06:15 AM
Analysis of liquid hammer phenomenon: the invisible killer of compressor damage
Many more using your favorite search engine.
Surface Condenser (Htri)Started by Guest_Prim_* , 08 Apr 2026 |
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Condenser DesignStarted by Guest_Kentucky08_* , 07 Dec 2025 |
