Hello, the attached image shows the air flow data for gas filter. I'm looking for the unit suitable for my current job : Ammonia gas, inlet pressure 9barg, temperature 25degC, outlet pressure assumed to be 8.95barg (0.05bar drop across the filter), actual flow rate requirement is 100L/min.
Supplier proposed the unit with 7micron pore size (39 std L/min at 0.34bar pressure different; 82 std L/min at 0.68bar pressure different; 130 std L/min at 1bar pressure different).
My question is, the actual pressure drop only 0.05bar, then i can only take the reference "39 std L/min at 0.34bar pressure different". To convert to ammonia gas actual flow rate =>using ammonia gas conversion factor, 39std L/min / 0.772 = 50.5 std L/min; and then apply real gas flow equation Qa = Qs(Ps/Pa)(Ta/Ts) or Qa = 50.5 (1/10)(298/293), Q actual =>5.13 L/min. The calculated actual flow rate only 5.13L/min. Does the calculation make sense? Or is there any other way to interpret the air flow data table below?
Thanks in advance.
Gas filter air flow data table.pdf 333.33KB
12 downloads
Edited by worrier, 25 November 2025 - 10:43 AM.
