3
Tsv Set Pressures
#1 SHIRAM
SHIRAM
  • 3 posts
Posted 27 June 2026 - 03:23 AM
Dear Gents,
In our product transfer unit TSV are provided on transfer lines from Tank to loading bay. TSV set pressures 12 bar are observed to match the pumps shut off pressure when operated at minimum flows.Now we need to reset the TSV set pressures,as observed frequent activation leading to maintenance.Whats should be the revised TSV pressure .considering no change in pump operation.
  • 7,055 posts
Posted 27 June 2026 - 04:48 AM
Thermal Safety Valves
Weird to me, you cannot change the setpoint as your will.
It has been in use for purpose. If you intend to change the set point you need to perform a safety analysis.
#3 latexman
  • 1,928 posts
Posted 27 June 2026 - 02:12 PM
What is design pressure of transfer lines?  What size, schedule, and material is the pipe?
#4 SHIRAM
SHIRAM
  • 3 posts
Posted 29 June 2026 - 10:40 AM
Design pressure of the line is 12 bar.Line size is 3 ",schedule 40 .Carbon steel.
#5 latexman
  • 1,928 posts
Posted 29 June 2026 - 11:13 AM
Set pressure of TSV can only be reduced, since line design pressure is 12 barg. Is that what you want? I think not, but the design pressure cannot be exceeded per Code. Time to change the focus of the investigation.
#6 Pilesar
  • 1,694 posts
Posted 29 June 2026 - 08:32 PM
Assuming this is a centrifugal pump, consider replacing the pump impeller with a smaller size. Or set a total flow controller to include forward flow plus recycle flow to keep the pump operating out on its pump curve. The smaller impeller is the better option.
#7 Ranga v
Ranga v
  • 35 posts
Posted 01 July 2026 - 03:41 AM
