Most general-service valves in oil and gas plants use carbon steel bodies. It's cost-effective, widely available, and performs well at ambient and elevated temperatures. But take carbon steel below -29°C and its Charpy impact values drop off a cliff. The material transitions from ductile to brittle behavior. Under stress, instead of deforming plastically, it cracks. A valve body that holds pressure perfectly at 20°C can fracture catastrophically at cryogenic temperatures.
LNG service means sustained exposure to fluids at -162°C or lower. In some applications, including liquid nitrogen and liquid helium service, temperatures reach -196°C. Carbon steel is simply not an option. You need an austenitic stainless steel — and within that family, the 316L series is the workhorse of cryogenic valve construction.
The Case for 316L Stainless SteelAustenitic stainless steels have a face-centered cubic crystal structure that does not exhibit a ductile-to-brittle transition at cryogenic temperatures. That's the fundamental reason 316L remains tough and ductile at -196°C while ferritic and martensitic steels do not.
The "L" in 316L designates low carbon content — typically capped at 0.03%. This matters for two reasons. First, it minimizes carbide precipitation during welding, which preserves corrosion resistance in the heat-affected zones. Second, it improves intergranular corrosion resistance, which is relevant in LNG service where trace contaminants in the fluid can be aggressive over time.
316L also offers good general corrosion resistance, compatibility with a wide range of process fluids, and a long track record in cryogenic service. It is not the cheapest stainless steel available, but it is the most cost-effective choice when you factor in reliability and code compliance.
Forged F316L vs Cast CF3M: What's the Difference?In valve manufacturing, the same nominal chemistry can be delivered in two forms: forged bar or forged components made from F316L, and castings made from CF3M. The ASTM designations differ — F316L covers forged material, CF3M covers investment castings — but the composition is essentially equivalent. The difference lies in the manufacturing process and the resulting metallurgical structure.
Forged F316LForging refines the grain structure. The mechanical working that happens during forging aligns the grain flow with the part geometry, which improves mechanical properties — particularly toughness and fatigue resistance. Forged material also tends to have fewer internal defects. No porosity, no shrinkage cavities, no sand inclusions. For critical components like stems, bonnets, and small-bore valve bodies, forging is the preferred route.
The [cryogenic valve](#) bodies that FLOWKS supplies for small and medium sizes are typically machined from forged F316L bar stock. The result is a dense, homogeneous structure with consistent mechanical properties throughout the cross-section.
Cast CF3MCasting allows more complex geometries that would be difficult or wasteful to machine from solid bar. For larger valve bodies — say, a 12-inch or 14-inch cryogenic ball valve — casting is often the only practical manufacturing method. CF3M castings can be produced in near-net shape, reducing machining time and material waste.
The trade-off is that castings inherently carry more risk of internal defects. Even with modern investment casting techniques and rigorous NDE, porosity and inclusions can occur. That's why cast cryogenic valve bodies require 100% radiographic examination to ASME or equivalent standards. When the casting quality is controlled and verified, CF3M performs adequately in cryogenic service.
Choosing Between ThemThe selection between forged F316L and cast CF3M usually comes down to size and pressure class rather than a simple preference. Small-bore valves — up to about 4 inches — are almost always forged because the material cost is low relative to the value of the superior mechanical properties. Larger valves are typically cast because forging a 10-inch body from bar stock is economically impractical.
There are also hybrid approaches. A [FLOWKS valve](#) might use a cast CF3M body with forged F316L stems, bonnets, and other pressure-containing components where mechanical integrity is most critical. This combination gives you the geometric flexibility of casting where you need it and the structural integrity of forging where it matters most.
Low-Temperature Impact Toughness: The Real TestComposition alone doesn't qualify a material for cryogenic service. The decisive qualification is impact toughness — specifically, Charpy V-notch testing at the minimum design temperature. Both F316L and CF3M are tested at -196°C, and the results must meet the minimum absorbed energy values specified by the applicable code (ASME B31.3, for example).
In practice, both materials pass comfortably when properly processed. But forged F316L typically shows higher and more consistent impact values than cast CF3M, which is another reason it's preferred for the most critical pressure-boundary parts.
SummaryMaterial selection for cryogenic valve bodies is not about picking the most exotic alloy. It's about matching the right grade, form, and manufacturing process to the specific service conditions. For LNG plants like Sumber, where reliability is non-negotiable, the F316L/CF3M combination provides a proven, code-compliant, and economically sound solution.
**FLOWKS production range covers ball valves, control valves, gate valves, globe valves, check valves, strainers, knife gate valves, and plug valves.**
**FLOWKS — How Quality Lasts!
