I did quite a lot of research about self-cleaning filtration systems and, as far as I understood, the best way to separate a 1% of melted hot melt glue from a 2% caustic soda solution, is a vertical centrifuge.
The fact is that quite many kind of glue have a specific weight of 1 (1ton per cubic meter) while the caustic soda solution is 1,02 and the difference isn't much.
Any advise or previous experiences data are really appreciated.
Thanks in advance.
A little more data:
hot melt glue to be separated from liquid = 1%
Hot melt glue softening point = 75°C
Hot melt melting point = 130°C
Temperature of liquid (caustic soda solution) = 85°C
Flow rate 4000 lt/hour (1100 gal/hour)
Hot Melt Glue Filtration
Started by Guest_Giorgio_*, Oct 21 2003 01:31 PM
![]() Amine System FiltrationStarted by Guest_Hanaa_* , 09 Jan 2022 |
FiltrationStarted by Guest_rajshekhar_* , 02 Oct 2019 |
Zinc Mass Filtration IssueStarted by Guest_nagkem89_* , 27 Sep 2019 |
Rich Amine FiltrationStarted by Guest_nsr.almasi_* , 15 Jun 2019 |
![]() Filtration - Plate Filter PressStarted by Guest_Starlord25_* , 23 Sep 2016 |
