I need information on how to generate the relationship between irregular shape to standard orifice size. I want to use in calculating the flow of fluid through the orifice.
I would appreciate urgent responce.
Relationship Between Irregular Shape And Stardard Oriifice Size.
Started by asade abiodun, Jan 26 2007 07:52 AM
Posted 26 January 2007 - 07:52 AM
Posted 26 January 2007 - 08:37 AM
I remember trying to work out the flow through a perforated plate.
It was the same as the flow through a single-orifice of the same flow-area - that was according to Miller, I think. Miller or Crane.
So, I think you could just work out the flow area (eg find a circle with the same area as your irregular shape) and go from there.
Anyone else?
- Steve.
Anyone else?
- Steve.
QUOTE (asade abiodun @ Jan 26 2007, 12:52 PM) <{POST_SNAPBACK}>
Posted 26 January 2007 - 08:29 PM
Well I believe that there is more to it because as the ratio of the Circumference to Area becomes larger, the orifice becomes less efficient. Or, the "C" will decrease.
A literature search would give some insight into this effect and might help in making an initial estimate. But, regardless, I believe it can only be proven by testing.
Posted 26 January 2007 - 09:57 PM
Hi Asade
I think that you need estimate is the flow for an irregular hole.
Attached, the equation and example for gas flow, was extracted from GPSA Engineering Data Book, Section 3: Measurement , page 16: Pipe (Tube) Rupture – Gas.
Maximum Nozzle Size In The Api 650 TankStarted by Guest_rudiawan_* , 18 Oct 2023 |
Answered
Fire Zone Flare SizeStarted by Guest_seuenergy_* , 01 Jun 2023 |
Generic Fire Size Calculation For Different MaterialsStarted by Guest_Dormelius_* , 20 Apr 2023 |
Bypass Line SizeStarted by Guest_Fatima105_* , 09 Feb 2023 |
Answered
Psv Bypass Line SizeStarted by Guest_R_Gowtham_* , 06 Jun 2022 |
