Can some one help me in sizing Rupture Disk for Non-newtonian fluid. I need information on how to size Rupture disk in such services?
Rd For Non-newtonian Fluid
Started by wini, Feb 12 2007 12:12 AM
Posted 12 February 2007 - 12:12 AM
Posted 12 February 2007 - 06:48 AM
I invite you to read my series on Rupture Disks, found on this website. At the home page, on the left hand side, click on "Free Articles", then click on "Pressure Relief Design".
You will see that I strongly recommend the use of the Resistance to Flow Method for sizing purposes. This method of sizing consideres the rupture disk as just another piping component. The only problem will be in that you will need to find the proper method to determine frictional loss for your particular non-newtonian fluid in your system. So in a nutshell, having a rupture disk in the piping system is not an issue, coming up with the correct algorithm to determine friction factor will be.
Posted 14 February 2007 - 01:51 AM
Dear Phil Leckner,
Thanks for your reply.
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Excel Based Calculator For Fluid Bed DryersStarted by Guest_outcast_* , 15 Mar 2023 |
Low Velocity Problem Of Fluid In Hairpin Heat ExchangersStarted by Guest_AnbIran_* , 16 Jan 2023 |
Temperature Rise Of Fluid Due To Friction Of The PipeStarted by Guest_panagiotis_* , 17 Dec 2022 |
Pressure Of Fluid And Heat TransferStarted by Guest_Jaldhipatel_* , 14 Jun 2021 |
