Water Hammer?
#1 sfhh
sfhh
  • 11 posts
Posted 30 October 2003 - 10:43 PM
I want to combine 2 liquid streams(pipes) at different temperatures(say 60C and 130 C) into one stream,
do I have to use the static mixer ? Or Can I directly join them together (in this case,will it cause water hammer?)
Thanks !
sfhh
#2 SDCHEM
SDCHEM
  • 5 posts
Posted 04 November 2003 - 09:56 AM
Please clarify exact conditions.Why do you need to do that?what are the liq streams.?
regards,
sd
#3 Guest_Guest_ShaunHill_*
  • guestGuests
Posted 03 December 2003 - 03:56 PM
Water hammer is caused by an abrupt change in momentum. ie the sudden opening or closing of a valve.
The temperatures of the two liquid streams will not cause any water hammer.
What you should look at are the pressures of your two streams to ensure that the hydraulics are good, but I would not expect any "water hammer" issues if you just T the two streams together.
A static mixer will speed up mixing of the two streams, however sufficient turbulence in the pipe will mix the fluids as well.
