Crude Blending
Posted 24 February 2007 - 05:52 AM
At present we are processing low TAN crude oil in our refinery. To increase the profitability, we are planning to implement cure oil blending facility of high TAN & low TAN in cure oil basket. In this connection, I’m interested to know whether the operation is satisfactory in a refinery of capacity around 10 MMTPA. How much cost is involved to implement the same? Whether simple in-line blending with analyzer or any catalytic (proprietary/ non-proprietary ) process is involved like decarboxylation and what will be the % conversion? Forwarding any paper or reference will be highly appreciated retaled to the topic.
Thanks & regards,
Posted 13 July 2010 - 12:59 PM
Thanks & regards,
Please let me know if you got any data on this??
Posted 04 August 2010 - 09:03 AM
http://www.jiskoot.com/Blending
Posted 11 August 2010 - 01:24 AM
I think that the scope of your question is a little broad. I am not a corrosion expert, but I have been involved in similar evaluations in our refineries, and you need quite some evaluations before you can run high TAN crudes.
The first step should be to evaluate the operating window of all your units, with repect to TAN, metals content, and other relevant parameters. Once you know that, you can evaluate how much of the new high TAN crude can you blend in the feed of the refinery.
How you mix the different crudes depends on the type of tanks and the conditions at which you are storing the feed. We do use different crude types at different feed percentages, and have no blending facilities.
After these considerations, if you want to run more of the high TAN crude than the present configuration allows you, you have to see where are the bottlenecks and find measures to remove them. One option could be to just add corrosion inhibitors in the most problematic areas.
You can see the below link from the Oil&Gas journal with a discussion on the topic.
http://www.ogj.com/i...nic-crudes.html
Hope this helps!
Posted 15 August 2010 - 03:50 AM
Thanks & regards,
Dear,
Can you give some prior backgrounds like, is it like you are an authority who intends to know the possibility of existing facility up gradation for processing capabilities for high TAN crudes and economics involved in it. I see this as a big project of revamp of a refinery, and for the same you need to approach a consultancy organization who are expertise in this area.
This is absolutely feasible as far as my experience is concerned, I got the opportunity in past to associate with a project where a refinery complex was revamped for high sulphur bearing crudes verses it's original installation to process low sulphur bearing crudes.
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Quantitative Risk Assessment Of Onshore Crude Oil PipelinesStarted by Guest_Mansi_* , 14 Feb 2024 |
Crude Oil Storage CapacityStarted by Guest_Noman97_* , 19 Jan 2024 |
Crude Oil Stripping (H2S Conc. Specified In Gas Phase Problem)Started by Guest_nabeelsp1036_* , 16 Jun 2023 |
