This is the case of PSA in series of PSA to ultra-purify H2 stream:
In ammonia production technology,Pure H2 is produced through pressure swing adsorption resulting into about 4 ppm CO (max) slip with H2 stream.This is MUST to safeguard synthesis catalyst against catalytic poison by oxygenated compounds.
A small H2 stream is sent to the other plant for production of caprolactam.Here, Pure H2 is further purified through their PSA(ie so-called series run) to reduce CO content further . Its regenerating stream to vent contains ~60 ppm CO in tail gas, as mentioned in process flow diagram.
1] Can PSA purify further gases containing almost trace impurities?
2] What is the limit / criteria to purify from ppm to ppb lvel in adsorption technology???????????
3] Gas chromatography will measure such a low level mpurities?
Thanks in advance..........................
D R Dave
