Pipe sizing formula to check velocity?
and check diameter of the pipe
Formulae For Pipe Sizing For One Phase Flow
Started by GIMC, May 18 2007 03:05 AM
Posted 18 May 2007 - 03:05 AM
Posted 18 May 2007 - 07:04 AM
API Recommended Practice 14E, 5th Edition, Section 2, Pipe Design.
The pipe diameter is not checked; it is calculated.
Posted 18 May 2007 - 11:15 AM
If you don't have API then any book on fluids or Perry's Chemical Engineering Handbook will do. I'm sure there is even stuff on this in the Mechanical engineering handbooks.
Posted 21 May 2007 - 11:15 AM
Crane TP410 is a good reference to have.
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
