Hello every one,
Please help with reliable set of equations used to calculate the pressure drop across a catalyst bed. highly appreciated if any free simple software is available.
Kind reagrds
Pressure Drop In Catalyst Bed
Started by Alawi, Jun 03 2007 12:49 AM
Posted 03 June 2007 - 12:49 AM
Guest_saeid_*
Posted 12 December 2007 - 08:10 AM
dear alawi
some catalyst manufacturer get press drop across the catalyst vs gas velocity.
you can contact with your catalyst manufacturer.
Posted 17 December 2007 - 09:16 AM
Dear,
I hope the reactor which you have mentioned here is a fixed bed reactor and, if so, you can calculate the pressure drop by using <b>Ergun Equation</b><u></u>.
Pressure drop is calculated in terms of (ΔP/L), the pressure drop per unit length of packing.
Posted 25 June 2010 - 07:54 AM
Hello
Yeah, try using the Ergun equation for modeling the pressure drop through the reactor.
It looks like the following:
dP/dW=[-(150(1-Φ)^2)/Φ^3 (μ*u)/〖d_p〗^2 -(〖1,75(1-Φ) ρ〗_gas u^2)/(d_p Φ^3 )](1-Φ) A_c ρ_cat
where,
u = the spacial velocity of the gas,
rho = the gas density
fi = the bed's void factor
Ac = the reactor's section area
where,
Posted 26 June 2010 - 06:34 AM
Using Ergun equation to predict pressure drop in fixed bed reactor requires data from catalyst vendor which can be proprietary or unavailable.
In such cases developing a simple Mathematical Model based on Ergun Equation can really help:
From operating plant actual ∆P in reactor for various flow rates can be recorded and plotted in as shown in attachment. This type of data can be represented as:
∆P
---- = [ A*(V)] + [B *(V2)]
L
Where A, B = Constants derived from graph.
This should solve the problem!
∆P
L
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
