Gasket Compatibility With Styrene
#1 MKPrcsEngr
MKPrcsEngr
Posted 18 June 2007 - 06:25 PM
What material of gasket would be good for steel braided hose that will be transporting Styrene? I am transporting Styrene from a tank to a heat exchanger to cool it.
#2 latexman
  • 1,828 posts
Posted 18 June 2007 - 09:39 PM
What type connections? Quick connect, dry disconnect, screwed, flanged, etc? If quick connect or dry disconnect, what is offered as choices?
#3 MKPrcsEngr
MKPrcsEngr
Posted 19 June 2007 - 12:30 AM
The hose is 4" and has ANSI 150# flanged connections.
#4 Doggert
Doggert
  • 46 posts
Posted 19 June 2007 - 08:01 AM
When I worked with stryene in the past, we always used Viton gaskets.
#5 latexman
  • 1,828 posts
Posted 20 June 2007 - 08:16 AM
Spiral wound SS with graphite filler.
#6 RAM Gaskets
RAM Gaskets
Posted 25 October 2007 - 08:29 AM
For any members with gasket queries, I thought the following resources maybe of interest:
A general guide to gasket design.
A guide to gasket materials and their properties.
A guide to gasket chemical resistance.
A guide to gasket fitting.
