can anyone suggest how to seperate acetone+methanol mixture?
Feed composition : Acetone:81%,methanol : 16%,water :3%
Desired purity : Acetone:99%,METHANOL : 0.1%,WATER: LESS THAN 1.0%
Presently we are doing extractive distillation with water but however we cannot able to acheive the above purity.
Acetone+methanol Seperation
Started by bhaskaran, Jul 23 2007 07:31 AM
Posted 23 July 2007 - 07:31 AM
Posted 24 July 2007 - 07:21 AM
QUOTE (bhaskaran @ Jul 23 2007, 03:31 PM) <{POST_SNAPBACK}>
Looking at equilibrium curve I have generated using PROII, it tells you you have an azeotrope at a composition of 80% mol. This means you cannot get more than that separation without changing the compositon. The curve was generated at atmospheric pressure.
Posted 24 July 2007 - 11:34 PM
Dear mostashar,
Eventhough it is an azeotrope we can able to bring methanol content 1% by addition of water(extractive distillation).My question is how to reduce methanol content further (<0.1%)?
Thanx
Bhaskaran
Thanx
Bhaskaran
Posted 25 July 2007 - 05:54 AM
QUOTE (bhaskaran @ Jul 25 2007, 07:34 AM) <{POST_SNAPBACK}>
Dear mostashar,
Thanx
Bhaskaran
Thanx
Bhaskaran
Have you tried to use Hysys, Aspen or PRO II to simulate the column and think of some debottlenecking.
![]() Gas Hydrate Inhibition: Calculations For Meg/methanol InjectionStarted by Guest_PYG_* , 30 Sep 2019 |
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
![]() Flash Seperation For N-Butane IsomerizationStarted by Guest_CHEMICAL_LOVER_* , 04 Dec 2024 |
Variables That Affect Energy Consumption Of Methanol PlantStarted by Guest_mobody_* , 15 May 2024 |
Methanol ProductionStarted by Guest_Manue_* , 21 Mar 2024 |
