Hello ChemEng Gurus,
I would greatly appreciate some points in the right direction, as I think I may be incredibly confused around this area of heat transfer.
We are on a project of converting plastics into diesel oil. We have a screw barrel of length 4.46 mt . The outer surface of the barrel is exposed to 400 deg celsius through a heater of 264 kw. Inside surface has to be maintained at 400 deg celsius. I want to know how to calculate the time required to maintain the same temperature ( 400 deg Celsius) at the inside surface of the Barrel. Inner diameter is 170mm and outside diameter is 320mm. All the suitable formula to calculate rate of heat flow?
Heat And Mass Transfer
Started by ajith, Aug 10 2007 05:30 AM
No replies to this topic
Posted 10 August 2007 - 05:30 AM
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Mass Balance ErrorStarted by Guest_Mohammad3799_* , 19 Feb 2024 |
