I am looking for advice on heat exchanger selection for seawater applications. Actually, the cooling water will be from a salt water cooling tower, so the concentrations will be even higher than seawater.
Currently, we are looking at plate and frame with titanium plates. The lead times for the titanium plates are terrible. I was also a little concerned about using plate and frame with seawater because of the potential for bio fouling. Does anyone have any experience or advice?
Thanks,
Mike
Seawater Heat Exchangers
Started by mvancleave, Aug 13 2007 08:02 PM
Posted 13 August 2007 - 08:02 PM
Posted 14 August 2007 - 12:40 AM
QUOTE (mvancleave @ Aug 14 2007, 04:02 AM) <{POST_SNAPBACK}>
Thanks,
Mike
Thanks,
Mike
Dear Mike ,
You can think about considering 70:30 Cu:Ni Alloy for sea water application. This will be cheaper than Ti exchangers, We have specified this in many shell & tube exchangers. You may contact the plate & frame exchanger vendor regarding delivery of plates made of this material .
Vinay
Posted 14 August 2007 - 01:28 AM
A useful reference on above subject can be found in attached ECI paper at
http://services.bepr...i/heatexchanger
I have atached a copy of this paper with my post as well. It specify that to counter biological attack , the velocity in the tubes ( interplate in your case) shall be large enough to counter biological fouling. The best advice can come from exchanger vendors only as most of the plate exchanger designs are properitery in nature.
Vinay
Vinay
Posted 15 August 2007 - 08:39 PM
QUOTE (vinay @ Aug 14 2007, 12:40 AM) <{POST_SNAPBACK}>
Thanks,
Mike
Thanks,
Mike
Dear Mike ,
Vinay
Yeap...70:30 Cu:Ni Alloy may be used for sea water application.
Please keep in mind that there is low velocity limitation (3 - 3.5 m/s) for this 70/30 Cu Ni whilst there is almost no limitation on the titanium.
PHE has low tendencies of fouling compare to S&T due to turbulence effect (read more HERE, HERE). MIC may occured at low velocity. Normal recommendation is to keep it above 4 m/s. Check with PHE vendor on channel velocity in PHE.
JoeWong
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Waste Heat BoilerStarted by Guest_Prim_* , 25 Apr 2026 |
