I am trying to simulate a compressor driven by a extraction steam turbine . Extraction turbine is a basically a combination of 2 turbines . But I am not able to understand how to add the two energy stream from the turbines & put to the compressor.
Can anybody help me ?
HK
Hysys
Started by HKk, Aug 31 2007 09:15 AM
Posted 31 August 2007 - 09:15 AM
Posted 06 September 2007 - 09:57 AM
You can mix the two energy streams to give the total energy. This can then be attached to the compressor, directly or via a SET operation.
Posted 08 September 2007 - 12:35 PM
QUOTE (HKk @ Aug 31 2007, 05:15 PM) <{POST_SNAPBACK}>
HK
HK
Just use a mixer, as you do with material streams, to combine both energy streams and link them to the compressor.
cheers,
SM
Simulating A Single Tube Heat Exchanger In Aspen HysysStarted by Guest_catia_* , 02 May 2024 |
Aspen Hysys Training Opportunities For Six Individuals Within Our InduStarted by Guest_Hafiz_Che_* , 30 Apr 2024 |
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catia_* , 22 Apr 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Extension Reaction Kinetic In HysysStarted by Guest_Ulbert Zsolt_* , 29 Mar 2024 |
