i have a problem in switching my project to dynamic mode when i clicked dynamic assistant button. o y.. i'm using component splitter. it was showed that component splitter is in red cross sign. i cannot change it to green check. is there anything wrong with my input or what should i do to make it become green check?
please help me.. thanks b4
Dynamic Assistant
Started by myins, Oct 04 2007 12:36 AM
Posted 04 October 2007 - 12:36 AM
Posted 05 November 2007 - 03:26 AM
Dear,
to view the problem with your dynamic mode, go to 'Other' tab on Dynamic Assistant window. Click on "Tell me why" will pop-up a massage box, which will provide you some facts about your defined system. It may help you.
manish mahale.
manish mahale.
Posted 06 November 2007 - 12:45 PM
Component splitters don't work too well in dynamics, since they are just mathematical constructs. However, you can still use them in dynamics, but you can never get the assistant to like them. Just ignore the red cross in this case if you have to use the component splitter for your simulation.
Posted 07 November 2007 - 11:44 PM
thanx friends, ill try to fix it
Posted 07 November 2007 - 11:49 PM
Posted 07 November 2007 - 11:58 PM
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
Dynamic Simulation After Feed Flow ReductionStarted by Guest_Kakashi-01_* , 20 Mar 2025 |
Converting A Static Simulation To Dynamic SimulationStarted by Guest_tomr91_* , 26 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
Static Simulation To Dynamic Simulation Of CduStarted by Guest_tomr91_* , 09 Jan 2025 |
