Just wondering what kind of cooling tower temperature drop to expect when cooling tower is operating with all the fans off and no evaporative cooling. If water at 450 gpm @ 95 deg F (from chiller condenser) enters cooling tower water distribution on the coldest winter day say -20 deg C dry bulb, what kind of temperature drop is expected. I'm designing a cooling tower by-pass line to divert some of the cooling water return (going back to the tower) to go directly into the chiller condenser when outisde temperature is very low.
Cooling Tower Load W/chiller Operation
Started by toronto engineer, Oct 09 2007 09:17 PM
Posted 09 October 2007 - 09:17 PM
Posted 10 October 2007 - 07:48 AM
I would contact the cooling tower vendor. You will need to know the model, fill type, etc.
Just get a few things straight: it is usually not a good idea to mix up your units of measurement. Either use gpm and deg. F or m3/h and deg. C.
Also, you need to know the wet bulb temperature when you rate a cooling tower. There will always be evaporative cooling when there is water flowing in contact with air, and that is what drives the performance of the tower.
Isn't there a problem with freezing up the tower when you reduce the water flow? Minus 20 deg. C sounds awfully low.
Posted 11 October 2007 - 11:27 AM
Dear,
Here are some articles in the following journals related to your query,
http://www3.intersci...n...=1&SRETRY=0
http://www.sciencedi...0a4d14104aeb5e0
And a very useful article on Coolin water is availabe here in Cheresources and a DOS programm for
the cooling tower calculations,
http://www.cheresour...ctowerszz.shtml
As well the same query is discussed in the forums below
http://www.eng-tips....d=184967&page=7
I hope that it will help you.
Padmakar Katre
Padmakar Katre
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
Psv Fire Case Relief Load CalculationStarted by Guest_mahmooddalvi09_* , 21 Feb 2024 |
Minimum Tower DiameterStarted by Guest_AnbIran_* , 17 Nov 2023 |
Sizing Of Cooling Water Pipe LineStarted by Guest_Asif Azeez_* , 08 Jan 2021 |
Heating And Cooling Circuit DesignStarted by Guest_AAZIZ_* , 20 Jan 2024 |
