I want to Know how the distillation of C3 cut from the crude oils takes place?
I want to separate the propylene from it.
C3 cut contains propane, propylene and other light components. (I don't know the percentage)
Propylene boils at 225ºK i.e. (approximately -50ºC)
I saw a distillation column in which light component leave the column from the top, propane from the bottom, and propylene from the upper side, I have drawn a rough diagram of distillation column.
The Pressure inside the column is 2.24 Psi g.
My Question is: At what pressure and temperature I will get Propylene out from the distillation column?
