Dear friends,
I want to calculate the stack height for leading the unscrubbed gas to the atmosphere. If any one is having knowledge about the same please share it.
Stack Height
Started by Hariharasudhan.D, Nov 23 2007 02:36 AM
Posted 23 November 2007 - 02:36 AM
Posted 25 November 2007 - 10:37 AM
Dear,
Consider dispersion analysis is one of the option to find the safe height to vent the gases to atmosphere.Along with the above consider the factors as the exit velocity, buoyancy effects and wind speed; it may also be affected by the local topography. It denotes the maximum height of the centre of a plume path above the level of the ground.As well go through ANSI Z9.5.
Here is one link which you may find useful
http://www.ajdesigne...on_physical.php
Posted 26 November 2007 - 12:10 AM
Dear Padmakar,
Thank you for your reply and particularly giving the standard for designing the stack.
I have also checked the web page you posted.
Thanks & regards,
D.Hariharasudhan.
Thanks & regards,
D.Hariharasudhan.
QUOTE (Padmakar S Katre @ Nov 25 2007, 10:37 AM) <{POST_SNAPBACK}>
Dear,
Kettle Reboiler Designe Rules - Position Weir, Height Weir, Liquid LevStarted by Guest_Otthigh94_* , 17 Jan 2024 |
Gas Seal In Hydrogen Vent StackStarted by Guest_Afshin445_* , 27 Dec 2023 |
![]() Controlled Type Blowdown Through Vent Stack, Reach Mach 1Started by Guest_x127127@hotmail.com_* , 16 Dec 2017 |
