Question here is: 0.83 mach speed in a relief line... Is it really a problem?
In a recent project, in order to not have to shut-down production / cut and weld flare lines / hydrotest flare header again, we're considering to use an existent tie-in of reduced internal diameter (6"). In one of our relief study cases, relief from a PSV (R 8" 300# x 10" 150#) sized for blocked discharge is passing through this tie-in with 0.83 mach.
So it's exceeding, for example, Norsok's design criteria of 0.5 or up to 0.7 mach for Relief Lines. It's also exceeding, but not so much, ro.v2 < 200.000 criteria.
Is it really a problem? Lenght of this reduced diameter tie-in is not more than 5 meters / 15 feet.
Thanks,
Lucas
3 years exp - Oil & Gas Production Surface Installations
Sizing Relief Lines
Started by Lucas, Mar 04 2008 10:24 PM
Posted 04 March 2008 - 10:24 PM
Posted 04 March 2008 - 10:46 PM
Lucas,
The limits on velocity are normally imposed to limit vibrations and noise. There is no thermodynamic reason for the pipe not to evacuate fluids at 0.83 mach, provided the mechanical design in sound.
Of course, the client may not like the idea and impose his desires, but that is a separate matter.
So, for a short piece of pipe I see no trouble to going to 0.83 mach. Just support the pipe for sonic flow, which should be mechanically and conservatively safe.
Rajiv
Rajiv
Posted 05 March 2008 - 03:35 AM
Yes it is really a problem, if you cosider the scenario of poping up of PSV frequently.
Posted 05 March 2008 - 09:00 AM
I agree with Rajiv. I have also seen (evaluated) existing flare systems and calculated that existing velocities in certain number of lines are exceeding 0.8Mach, which is considered as practical maximum in relief lines feeding the common header.
Especially if line is very short, I think you should not have any further concerns. 0.83 is quite OK number.
Posted 05 March 2008 - 12:38 PM
Rajiv / Zauberberg
Thanks for your opinions. If you don't mind, can you explain what do you mean by "support the pipe for sonic flow"? Thanks again,
"mishra.anand72"
That's Ok, for many reasons we don't expect this PSV opening frequently.
Lucas
"mishra.anand72"
Lucas
Posted 06 March 2008 - 04:12 AM
Lucas,
I am not knowledegable on the exact criteria to use for support, but I do know that my piping guys are. If I write this requirement on a P&ID, the piping stress guys do the analysis.
I am aware of a number for frequency of the pipe structure which is used by some designers to analyse a pipe, in absence of any firm information. But I am not going to stick my neck out on this one! Best ask a stress guy.
Rajiv
Rajiv
Buffer Tank Sizing Upstream Screw CompressorStarted by Guest_Process_1601_* , Yesterday, 11:41 AM |
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Pressure Control Valve Issues For Gsw LinesStarted by Guest_fahadazh_* , 29 Mar 2024 |
