Please can you help me how can I solve a heat exchanger? I mean what is the required data to solve the exchanger?
Heat Exchanger Solving
Started by omaroma1, Mar 05 2008 08:28 AM
Posted 05 March 2008 - 08:28 AM
Posted 05 March 2008 - 10:35 AM
Omaroma my friend,
Please put at least some minimum effort to describe what is your problem exactly. Doing this way, there is no person in this Universe who can give you any valuable answer. And most of them will not even bother to guess what can be the issue here.
Are you sizing heat exchanger in some industrial software? What are your input (known) data, and what are the targets and constraints? What is given as process input in your calculations?
Please come with more detailed information.
Best regards,
Best regards,
Posted 05 March 2008 - 11:09 AM
Dear Omaroma,
I presume you are trying to find out required of a heat exchanger, or you want to know outlet temperatures of hot and cold streams, pressure drop, fouling etc. If o specify, the metod can be given.
smuk
smuk
Posted 07 March 2008 - 07:43 AM
Thanks every one
I wannt to use Hysys to get the duty of heat exchanger(stabilizer reboiler)shell and tube.
The hot side is a Hot oil and the cold side will be condensate with 130 C to be heated to 170 C.
Posted 15 March 2008 - 09:59 AM
Hi Omaroma,
Basically, you don't need HYSYS in order to calculate exchanger duty. What you need is:
- Hot oil mass flowrate
- Hot oil average heat capacity (average for inlet and outlet conditions)
- Hot oil temperature change (inlet - outlet)
Based on hot oil properties (you must have some data supplied), you can use any technical reference book (API, GPSA, Perry) for finding heat capacity of utility stream. As rough estimate, you can guess a value between 2.3 and 2.7 kJ/kg.C
If you want to do it for other purposes, bulding a stabilizer tower model with accurate feed and products data, operating conditions and exact tower configuration should yield in very accurate reboiler duty estimate, within +/-5% error.
Best of luck,
Best of luck,
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
