I would like to know, how to size the thermocompressor. The data available with me is motive steam flow rate 146kg/hr and pressure 7kg/cm2(a), vapor which is to be recompressed is saturated water vapor with flow rate of 379 kg/hr at 70°C. I need to know i) the discharge pressure and energy and ii) throte dimensions (venturi size). Please reply if further data still required.
Please suggest for the above
Design Of Thermocompresser
Started by Jiten_process, Mar 10 2008 04:50 AM
No replies to this topic
Posted 10 March 2008 - 04:50 AM
Absorber And Stripper Design - Eqbm Data?Started by Guest_ChemEngBoy26_* , 03 May 2026 |
Adsorber Design Essay QuestionsStarted by Guest_Kahirn_* , 10 May 2019 |
Scrubber DesignStarted by Guest_syamsundar_menon_* , 02 Jul 2018 |
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
