Dear Forum,
I'am currently working on my honours year design project - Production of 250 tonnes per day of propylene glycol. The method chosen is the hydrolysis of propylene oxide. I have been assigned to complete the chemical and mechanical engineerign design of the reactor involved within the process. The chemical engineering design has been completed with the following results using hysys and hand calculations and agree favourably:
The reactor is an isothermal CSTR and the reactions are exothermic. The reactor is kept at 125oC using cooling water.
Volume:21.5324 m3
Diameter: 2.634m
Height: 3.951m
The next stage is the mechanical engineering design of the CSTR. I was wondering if any members know which path to follow with regards to calculations? Or if they know any good books/material to use for the mechanical engineering design.
Any input would be highly appreciated.
Regards ChemEngStudent1
Cstr Mechanical Engineering Design
Started by ChemEngStudent1, Mar 28 2008 04:55 AM
No replies to this topic
Posted 28 March 2008 - 04:55 AM
Answered
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Design Compressor For 35% H2S & 1.05Ksca Suction PressureStarted by Guest_GanjiS_* , 29 Apr 2024 |
Basic Engineering Vs Detailed EngineeringStarted by Guest_poojabathula369@gmail.com_* , 24 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
