Generally, Sour water stripping unit consists of Feed Preparation tank – Sour water Storage Tank. This sour water storage tank provides sufficient residence time for liquid HC separation, HC that has not separated in the surge drum. These also essentially helps in downstream processing & have the benefit that:
Much less oil, if any, will reach the sulphur plant
Minimum oil removal will be needed from either stripper as liquid.
Longer sour water mixing to minimize feed composition fluctuations due to many sources of refinery sour water
Based on the above, it is decided to provide the Sour Water Storage tank in the sour water stripping unit (SWS)
1. This tank will have a large volume approximately 14000 m3 normally & first estimate measures this tank to be 30 m in diameter and 20 m height.
2. If the tank will be at lower pressure than the Collection Drum, there will be a pressure differential between the off gas of the collecting drum and the off gas of the Sour Water Storage tank. This will result in the flashing of NH3 and H2S from the tank. We cannot plan to route this to the SRU incinerator stack as this will result in H2S and NH3 emissions & will not be acceptable based on the environmental regulations at site.
Considering the environmental regulations, shall I expect expert comments on the:
1) Lower tank pressure than the collecting drum: use of BLOWER to suck the gas from the tank & discharge at 1.05 kg/cm2g so that same can be routed to SRU.
Or
2) Design of the tank: designing the large volume tank for internal pressures not more than 15 psig so that tank vent can be routed to SRU through pressure controller.
Or
Any additional information / comments?
