Hay all,
I have completed the Hydraulic Design of my column and am now moving on to the Mechanical Design. However it seems there are British Standard pipe size (even for column diameters of 7.5ft and 10ft as mine are!)
However I cannot find any information on these. Any tips of internet resources or where I am able to get this kind of information, and how to proceed regarding this!
Henry
Distillation Column Pipe Sizing
Started by , May 28 2008 12:56 PM
Posted 28 May 2008 - 12:56 PM
Posted 28 May 2008 - 07:39 PM
Henry,
First of all : is this a class project? Because while doing the design of columns, you need to take care of several internals like feed distributor etc. The size of the nozzles depend on the internals. I can give you more help only when I have such information.
abhishek
abhishek
Posted 29 May 2008 - 11:11 AM
Since you started your design with Kister's books, I'd recommend you to switch to "Distillation Operation" sections related to column inlets and outlets, reboiler connections etc.
These are chapters 2, 4, 5, and 7.
Pressure Control In Batch Distillation ColumnStarted by Guest_Femi_* , 14 May 2024 |
Buffer Tank Sizing Upstream Screw CompressorStarted by Guest_Process_1601_* , 09 May 2024 |
Age Impact On Pipe RoughnessStarted by Guest_Noman97_* , 09 May 2024 |
Calculate Mabp,wabp,cabp And Meabp From Distillation Astm D86 ResultsStarted by Guest_barks123_* , 30 Apr 2024 |
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
