Sweeping Gas
Started by mohammadhosseinzadeh, Jun 02 2008 02:20 AM
13 replies to this topic
Posted 02 June 2008 - 02:20 AM
would you please advise me regarding the following question?
How we can calculate required gas flow rate for sweeping of flare system?
or
What is important parameter which affect on sweeping flow rate?
or
Posted 02 June 2008 - 11:30 AM
Dear Mohammad,
For pipe type flares the purge or sweeping gas rate is a function of the minimum velocity for purge gas and the diameter of the flare tip. You can calculate the purge gas rate for flares with modern labyrinth or internal gas seals considering a conservative velocity of 0.04 ft/s. Multiplying this with the flare cross-sectional area in ft2 will give you the volume flow rate in ft3/s.
Alternatively you may use the following equation to calculate the purge gas rate for pipe type flares with diameter 457 to 914 mm.
Purge gas flow rate = 1.2E-5*d^3/M^0.565
Where,
purge gas rate is in m3/h
d = diameter of flare tip in mm (applicable to diameter range of 457 to 914 mm)
M = molecular weight of purge gas (purge gas could be inert gas such as N2 or fuel gas)
Hope this information is useful.
Where,
Posted 02 June 2008 - 03:51 PM
Mohammad,
I guest you have dropped me an email related to similar topic and i am yet to response to you. I take this opportunity to response to you...It is great that you raise similar question in order to get more inputs...
Flare sweeping gas flow determination...
There are many factors affecting it :
i) Flare tip design (multi-tube, pipe flare, tulip, etc)
ii) Purge gas type (combustible like fuel gas or non-combustible like nitrogen)
iii) Molecular weight
iv) gas composition
v) component
vi) Flare tip diameter
vii) External wind velocity
viii) wind shield
Others CheJedi, please add...
Before determine flare purge, first, you have to consider if purge reduction seal (i.e velocity seal, etc) is installed. With this seal, it significant reduce the purge rate (possibly 10 times or more).
The first method proposed by ankur is the experience approach where a velocity based on "rule of thumb" is used. However, this figure is different if seal is present. Secondly, sad to say that flare tip vendor will have different figures (large different)
The second method as proposed by Ankur is the Tan method (if not mistaken) which only take into account of molecular weight and tip diameter, have been used by many companies (well known) for sometime. However, there are other method like Husa, Herbert, Corbett, etc which is having different consideration and limitation. Lately API has recommended HUSA method.
Advise base on above discuss factors, looks at the limitation of the method with your particular case to select a proper method and last ensure your purge rate is not lower than rate requested by flare tip vendor.
Good luck.
iv) gas composition
v) component
viii) wind shield
Good luck.
Posted 04 June 2008 - 06:28 AM
your actions are highly appreciated.
JoeWong:
Would you please give more information about HUSA method or others method(Adress)?
API (section and Edition)
JoeWong:
Posted 04 June 2008 - 03:20 PM
Please refer to API Std 521 - ISO 23251 - Ed 5 - Jan 2007 - Pressure-relieving and Depressuring Systems, Section 7.3.3.3.3.
Please also read section 6.4.3.6.2.
Posted 05 June 2008 - 06:29 AM
QUOTE (JoeWong @ Jun 4 2008, 03:20 PM) <{POST_SNAPBACK}>
JoeWong:
Thank you for your advise,
unfortunathly i do not have access to this edition,I have access to API RP 521 1997
Posted 05 June 2008 - 09:36 AM
Maybe it doesn't apply in too many cases, but for a large flare system with an efficient seal, you might want to check for cooling of the (gas) contents of the flare system. Any volume reductions resulting from cooling will have to be met with an inflow of sweep gas. I suppose this is not often an important factor, but it could be at times.
Posted 05 June 2008 - 12:32 PM
Mohammad,
The HUSA equation is included in 2007 edition.
Are you still using 1997 edition ? I strongly encourage you to get a latest edition. There are several concepts changed, or i would prefer to say improvement in this revision (which i don't want to detail here). You should use the latest revision.
Posted 10 June 2008 - 11:19 AM
Dear Mohammad,
I am attaching the Husa correlation as an excel file I prepared. This should help you till the time you procure API STD 521.
Ankur
Ankur
#10
Posted 15 June 2008 - 12:54 AM
Thank U all friends, especially ankur which attached very useful exceel sheet.
#11
Posted 16 June 2008 - 03:40 AM
QUOTE (mohammadhosseinzadeh @ Jun 15 2008, 01:54 AM) <{POST_SNAPBACK}>
Dear friends:
As U know there is sweeping and purge gas that i tried to clear my purpose in the attached drawing.
please refer to attached drawing to find better my purpose.
Is this purge gas (husa calculation or others methods)included both purge & sweeping rate(as per my drawing) or there is diffrent method for sweeping rate calculation?
Posted 17 June 2008 - 08:27 PM
In my opinion. purge and sweeping are same although many "philosopher" differentiating them...
#13
Posted 15 January 2009 - 12:16 PM
QUOTE (ankur2061 @ Jun 10 2008, 12:19 PM) <{POST_SNAPBACK}>
Dear Mohammad,
Ankur
Ankur
Dear Forum Members,
The attached excel file is a revision of the earlier file which was referenced from BP stds. The new file is revised based on API STD 521, 5th edition, 2007.
Posted 16 January 2009 - 07:30 AM
QUOTE (JoeWong @ Jun 18 2008, 06:27 AM) <{POST_SNAPBACK}>
Dear mohammadhosseinzadeh,
I am also very clear to accept in principle JoeWong's statement;
with the slight modification that
Purging and Sweeping gas flows are equivalent term in connection with flare systems.
Where such gases perform a sort of Carrier/ Vehicle function(not necessarily Flammable or Combustible)
This helps in maintaining induced flow towards flare tip flame front and adds to the system's safety.
Best regards
Qalander
Sweeping Flow In A Hydrocarbon Flare.Started by Guest_aanita_* , 13 Jan 2011 |
Nitrogen Sweeping Method?Started by Guest_dan m_* , 12 Apr 2010 |
Flare Sweeping GasStarted by Guest_mohammadhosseinzadeh_* , 04 May 2008 |
