While reviewing flare systems we come across some plants having flare systems at two design pressures. One is a Low pressure flare system and other a high pressure flare system. I understand that the LP flare shall have subsonic velocity at flare tip and HP flare shall operate at sonic velocity at tip. This means HP flare shall offer more superimposed back pressure on relief valves discharging into it. Correct me if I am wrong.
The only benefit of HP flare as I could gather was that somekless combustion is possible without additional utilities.
My question is why should there be flare system swith two design pressures? Why cannot we have do away with HP flare system when we have an LP flare system?
Is there any guideline about Which relief streams shall we route to HP flare system and which to LP flare? When should we have a HP flare system?
Flare System Design
Started by benoyjohn, Apr 01 2004 04:45 AM
Posted 01 April 2004 - 04:45 AM
Posted 27 July 2004 - 12:04 AM
A complex can have two flare systems based on the back pressures involved. What is important is the set pressures of the PSV or other sources to the flare, rather than combustion efficiency of the flare itself. For instance if a tank essentially operating at atmospheric pressure is connected to the LP flare, it is not prudent to add a PSV whose set pressure and relieving rate is much higher. The back pressure generated in the header when this PSV relieves may be higher than the design pressure of the tank. For course HP flares are the first choice as with higher backpressures, one can reduce the size of the flare headers.
Posted 04 April 2012 - 06:02 AM
lp flare is the only choice when you have a low pressure system, like refrigerated atmospheric ammonia storage tanks. Hp flare system will reduce your costs as you can use smaller equipment.
Posted 05 April 2012 - 08:00 AM
Recently i was working on a project where vessels' design pressures ranged from 10 psig to 1250 psig. The HP flare had a max back pressure of 50 psig. Evidently, lower design pressure vessels (10 psig) could not be connected to the HP flare. That's why we had to arrange an LP flare.
Edited by P.Engr, 05 April 2012 - 08:01 AM.
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
