i want to find a solvent suitable for potassium phenate. this solvent should has to be immiscible with water. plz suggest some books, sites or solvents where the concerned information is available.
Suitable Solvent
Started by Guest_Guest_prashant_*, Apr 04 2004 09:58 AM
Posted 04 April 2004 - 09:58 AM
Posted 05 April 2004 - 02:32 AM
Potassium phenate can be viewed as a salt, of phenol and potassium hydroxide. The phenol will be present as the C6H5O- ion, and will have a strong affinity for water.
Unless you acidify and return the phenate ion to phenol, you will not find a suitable extration solvent.
Under acidic conditions, about any immiscible solvent would do (MIBK,toluene, ....) just to name a few.
The choice will be yours, and will depend on subsequent separations. I like the light solvents, because they are easy to recover by distillation, and also easy to strip from the water layer. Safety and toxicity will be an issue.
How To Handle Water Byproduct And Man Hydrolysis In The Dbp Solvent RoStarted by Guest_martzian_* , 20 May 2026 |
Solvent Carryover Emissions In Absorption ProcessStarted by Guest_TeeEng_* , 24 Oct 2023 |
Pump Suitable For Thick Slurry With FibersStarted by Guest_kangas_* , 23 Jun 2023 |
Which Software Is More Suitable For Simulation Of Catalytic ReformingStarted by Guest_AnbIran_* , 04 May 2023 |
Phenol Removal From Solvent (Methyl Isobutyl Ketone) In Aspen HysysStarted by Guest_HzO_* , 28 May 2021 |
