please enlighten on
As in a pipe flow when the exit pressure decreases, at critical prssure ratio, choking takes place & velocity do not increase further wih decrease in downstream pressure then howcome it is possibe to achieve supersonic flow in a pipeline, & what are the practical applications.
thanks in advance
Supersonic Flow
Started by man2k, Jun 25 2008 08:43 PM
Posted 25 June 2008 - 08:43 PM
Posted 28 June 2008 - 05:00 AM
In these cases we have "chocked flow" and the mass flowrate tends to be decreased.
Posted 28 June 2008 - 02:56 PM
QUOTE (man2k @ Jun 25 2008, 09:43 PM) <{POST_SNAPBACK}>
please enlighten on
thanks in advance
thanks in advance
thanks fallah,for ur reply.
but ......., i want to be bit clear.
actually i want to know how a supersonic flow of fluid can be achieved in a pipe flow.
Posted 28 June 2008 - 11:50 PM
man2k,
Please read this article.
http://en.wikipedia....De_Laval_nozzle
Hope it give you some idea how supersonic can be created in a special device.
One of the applications of supersonic is in rocket
Posted 29 June 2008 - 08:54 AM
I think the specific question has to do with gas flow at supersonic velocity INSIDE OF A PIPE - not in a DeLaval nozzle or through an orifice.
I believe the PowerPoint presentation done by the University of Texas centers on this important criteria at:
http://utwired.engr....4/mom/comp3.ppt
I like this presentation because it describes in detail what is actually happening in compressible flow - practically, and what can happen theoretically.
Posted 03 July 2008 - 01:49 AM
It is not possible to achive supersonic flow in pipes. To achive supersonic flow you must pass the fluid through converging-diverging nozzle or "DeLaval nozzle" as mentioned above by "Art Montemayor".
To achive supersonic velocity, fluid must be compressible.
Man2k,
I hope you would able to find your answer easily in lite of above mentioned points.
Man2k,
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Teg Dehydration Stripping Gas Flow RateStarted by Guest_SidRah_* , 20 Aug 2025 |
