A reciprocating type positive displacement pump is to be used for applications where a precise control of pressure is required in discharge. Suppose Q be the flowrate of pump & Q1 & Q2 are the minimum & maximum flows required in the downstream applications. A recirculation line from pump discharge to suction with a control valve is proposed for pressure control at 120 kg/cm2. The pressure at pump suction is 4kg/cm2 now what are the broad steps for sizing of a control valve in this case.The line sizes from pump discharge to CV & form Cv to suction are 3m 2"sch80 & 2m 3"sch80. What is a criteria when i shall go for two Cvs in series.
regards
Cv Sizing For Pressure Control Of Positive Displacement Pump
Started by rsk, Jul 18 2008 06:50 PM
Posted 18 July 2008 - 06:50 PM
Posted 21 July 2008 - 01:08 PM
rsk,
It's not clear whether you are interested in one or two control valves, but I can tell you that it doesn't matter. Neither will work. You do not want to put a control valve on the discharge of a PD pump, intending to control the pump's discharge pressure. A recip-type PD pump generates pulses that are shaped like half sine waves. You can think of those pulses as being flowrate or pressure, in doesn't matter. You'd be accurate in both cases. You do not want to use a control valve in the discharge to control either flow or pressure, since you cannot effectively do this in pulsating flow. Remember, half the time (for a simplex pump) the flowrate is zero. How do you control pressure then? You don't, unless you have an intermediate device, such as an accumulator, that can effectively smooth out the pulsations and produce a nearly steady flow (and pressure). While accumulators are somewhat effective, this is a tall order. I'd highly recommend that you consider alternate solutions or you relax your requirement for such steady pressure.
Posted 22 July 2008 - 09:35 AM
QUOTE (djack77494 @ Jul 21 2008, 01:08 PM) <{POST_SNAPBACK}>
rsk,
Dear rsk,hello,
Although much is very correctly pointed out by djack, at times it helps if the service application& process is elaborated.
Moreover the very concept of reciprocating motion of pistons/plungers/rods whatsoever can not permit smoothness in flow and/or pressure downstream of pump in question;you should realize.
Best regards
Qalander
Posted 23 July 2008 - 06:36 PM
Doug has rightly pointed out pulsating flow on recip-pump and accumulator to smoothen flow. This kind of system needs proper engineering to ensure a good control...
Dropping from 120 kg/cm2(g?) to 4 kg/cm2(g?) is likely to occur and potential lead to valve cavitation when it pressure recover from ?? kg/cm2(g?) in vena contracta (VC) to 4 kg/cm2(g?). Anti-cavitation trim or multiple CV may solve the cavitation problem...
Posted 24 July 2008 - 08:23 AM
I don't want to get stuck on the point, but I did want to clearly indicate that it is folly to try to use a control valve in pulsating flow service. Yes, you can use an accumulator to (somewhat) smooth out the flow and pressure, but you'll still maintain some of the pusating nature of your flow. A PD Pump itself is a flow control device (which is why they are sometimes called metering pumps). No additional flow control should be necessary. Many if not most PD pumps have adjustable strokes and/or speeds. If you want to control a process variable that depends on the flowrate through a PD pump, I would recommend that you control the pump's stroke or speed. I highly discourage any attempts to throttle the flow from the pump.
Posted 25 July 2008 - 01:43 AM
QUOTE (djack77494 @ Jul 24 2008, 09:23 AM) <{POST_SNAPBACK}>
Noted your concern.
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
