Co2 Separation From Flue Gasses
#1 Guest_Nitin Agarwal_*
  • guestGuests
Posted 23 April 2004 - 06:45 AM
tintin_74@aemail4u.com
At our complex we are facing shortage of CO2 for full conversion of ammonia to urea because of lower calrific value of natural gas. At the same time an appreciable quantity of cO2 is being vented along with flue gases from the stack of primary reformer in ammonia plant.
How can this CO2 extracted from flue gases economically so as the same can be used for urea production.
Kindly answer at tintin_74@aemail4u.com.
#2 Kameswara Rao
Kameswara Rao
  • 9 posts
Posted 23 April 2004 - 02:06 PM
I am surprised to note the co2 is not enough for the production of urea. you will have excess of co2 even with natural gas.
What process you are useing for the manufacture of urea.
Do you other wuse use this co2 for mfg of methonol?
You can use vetrocoke process for recoveryof co2 form flue gas.
kkrao22@hotmail.com
#3 Guest_Guest_*
Guest_Guest_*
  • guestGuests
Posted 24 April 2004 - 01:24 AM
We are making ammonia based on Topsoe's steam reforming technology & urea based on Snam's ammonia stripping technology.
We are not making any methonol etc but run PGR plant on continuous basis.
Average NCV of NG is around 8100 KCal / SM3 with no CO2 & higher hydrocarbons in it. We face approximately 250 TPD of CO2 shortage for making 2800 TPD of urea.
We percieve flue gasses of primary reformer a major source of recoverable CO2 which is currently being wasted & is looking for a viable technology for extracting the same & need inputs from all the readers.
Mr Rao it would be great if you can send some details of Vetrokokes tech for separating CO2 from flue gases.
#4 mbeychok
mbeychok
  • 364 posts
Posted 25 April 2004 - 05:11 PM
Nitin:
I strongly advise you not to use the Vetrocoke process. It is very old technology and the absorption solution contains arsenic which inevitably causes serious environmental problems because arsenic is highly toxic.
If you want to recover CO2 from your flue gases (and I am not sure that it is economically viable to do so), then I would suggest that you consider any of the various processes using amine solutions. I would also suggest that you have one of the major engineering-construction firms do a design and economics viability study for you. Don't try to do it yourself.
#5 Art Montemayor
Posted 26 April 2004 - 01:49 PM
Nitin:
What Milton is advising you is very correct and exactly what I also believe you should heed. Vetrocoke is not a bad process because it is old; it is a bad process because of the arsenic hazard it introduces. The Amine process is much older, but much more reliable and safer to use. I have recovered CO2 from flue gases using MEA for many years. I have designed and operated my own units sucessfully producing 99.5% CO2 (vol) as minimum purity. This is not a complicated nor arcane process. However, as Milton infers, the best solution for a serious study and identification of a credible alternative to obtaining excess CO2 is to comission a feasibility study to a recognized and acknowledged engineering firm. The economical viability depends on your existing, local conditions and market prices. You certainly will need a dependable and cheap source of low pressure steam (minimum 30 psig) in order to regenerate the Amine solution. This is the tradeoff of the amine process: the high steam demand for regeneration - and the outstanding cost item in the study. However, if you are presently running steam turbines under backpressure and having to condense your excess steam generation, you could have a very attractive situation where the idea may have merit and potential profit. Additionally, you will need incremental compressor capacity to bring the CO2 up to process pressure. Existing compressor capacity may also determine economic viability of the idea. It all depends on your situation and existing conditions. This is why Milton's suggestion makes all the sense and should be heeded in order to identify if there is an option that is worth an investment.
I hope this helps to point you in the right direction at the conceptual stage.
Spring, TX
#6 Guest_Nitin Agarwal_*
  • guestGuests
Posted 29 April 2004 - 01:21 AM
Thanks to everyone responding to my queries.
I would like to know is there any method / technology available for separating CO2 from flue gases using Magnesium hydroxide. If yes any details of it.
#7 Art Montemayor
Posted 29 April 2004 - 11:59 AM
I've not heard of any magnesium Hydroxide process.
If you have, please state the source, licensor, and characteristics - as well as regeneration requirements in Btu/lb CO removed.
Additionally, if you are still at the stage of contemplating a feasibility study, you would be wise in leaving the selection of the "correct" CO2 removal process to the engineering group doing the study. You stand to waste a lot of money and time dictating likes and preferences to a feasibility study prior to the actual, implemented, and published results. This is like putting on the shoe before the sock. The correct, or recommended process and its conditions must be left up to the study group doing the economic feasibility study. Just because a process exists, doesn't mean that it is the "right", correct, or recommended processs for you. It must dove-tail into your existing project scope of work in the study. Otherwise, it's a waste of time and money to try to force a specific process into a situation that may or may not apply - much like the pre-selection of the Vetrocoke process without knowledge of having to handle a hazardous material (that may not be practically allowed by local regulations).
