What fluid package to be selected for the following chemical composition.
HCL,Vinyl chloride monomer,Ethylenedichloride & chlorinated hydrocarbons - I want to seperate HCL using distillation column
could u tell me the fluid package to be used for this problem in Hysys as well as in Aspen plus.
Vinee
Fluid Package
Started by vinee, Aug 25 2008 02:15 AM
Posted 25 August 2008 - 02:15 AM
Posted 22 September 2008 - 01:07 AM
QUOTE (vinee @ Aug 25 2008, 03:15 AM) <{POST_SNAPBACK}>
Vinee
Vinee
To determine the fluid package for simulation, first we need to make sure there are polar component, if there are H2O, maybe we need to select NRTL, if there are electrolyte exist, we need to select ELEC as fluid package. Otherwise, we must select idea equilibruim according to the working condition, such as SRK, PR. Please do it by the help of Property Guide in Simulaiton software, such as Plus or HYSYS.
Best regards.
Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
Chiller Package With Different FootprintsStarted by Guest_nabeelsp1036_* , 24 Oct 2025 |
Two-Phase Fluid Flow Through An OrificeStarted by Guest_frwvelandria_* , 13 Oct 2025 |
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
